squeeforever
squeeforever's Avatar
02.25.2009, 07:53 PM
Originally Posted by emaxxnitro View Post
at that price just get the fma cell pro 10s its a wail of a charger, for 190$ charges up to in our case 2c with a 10amp max output.
http://www.fmadirect.com/new_applica...0s_charger.htm
The 1010B+ is also 10A and seems to have more features.
fastbaja5b
fastbaja5b's Avatar
02.25.2009, 08:11 PM
Back to the OP, the zippy packs you mention will do fine IF YOU GEAR IT BACK DOWN SO IT DOES AROUND 45MPH ON 6S
PLEASE RE-READ WHAT I JUST TYPED, SAY IT ALOUD A FEW TIMES TILL IT SINKS IN. WITH STOCK GEARING THOSE ZIPPYS WILL GET HOT AND PUFF!
A 5000 20c lipo should be able to output around 100amps. That would not be enough for an 1/8 MT geared for 45mph on 4s, you need 150amps or more for 4s useage with that gearing. Now on 6s those cells should be fine.
Look at it this way, a 4s 5000 20c lipo can do 1480watts (theoretical max, no losses factored for this number) at 75% it can do 1110 watts, or 1.5hp, not enough for a 12lb truck with tall gearing.
A 6s 5000 20c lipo can do 2200watts, factor in about 75% effecientcy, and you have 1650 watts, or 2.2 hp. I would not run a MT on 6s with any cell spec'd lower than the 5000 20c you mention. Unless you plan to run 35mph, then you can run less capable cells (maybe even maxamps).
A 12lb truck doing 45mph uses some juice. A good rule of thumb, is 150amps for 4s 125 for 5s, and 100 for 6s. If you plan to squeeze out the 60+ mph claim on the flux, 2 polyquest 6000 25c 3s packs in series will be the best bet... 2500watts after losses, or 3.3hp...
Ok so I understand this yet here in Australia they are being told that ESC's are blowing as they are running the 20t pinion in a flux and not the 25t for 6s? I mean WTF? By your logic I should go down to a 14-15 pinion to lower the amps, by their logic I'll blow everything up!
What is increasingly frustrating is the lack of response to my direct questions on this matter by email to castle creations, there are more and more savage flux - ESC go boom - videos coming onto You Tube, yet I can't get any clarification on this matter, just a lot of theorising.
Say Less, Do More.
02.25.2009, 08:33 PM
You can run smaller pinions, but you may find the motor undergeared, and it may run warm because of that. Otherwise it should be fine. If I were to buy a savage flux I would run 5s lipo and regear it to do around 42-45mph. That would most likely mean dropping 2 teeth on the pinion to a 23t. You can run it however you want, just take temps regularly and you will see what is not working. If you plan to run 6s, I would gear down a few teeth. Then keep an eye on the batts and if they get too hot you will need to drop a few more teeth. A MT on 6s that is geared for more than 55mph is generally a handful. That is why most of us gear for 45mph or so.
fastbaja5b
fastbaja5b's Avatar
02.25.2009, 08:38 PM
But if you go by this thread:
http://www.ausrc.com/forum/showthread.php?t=15868
He's being told his esc blew as he ran the 20t pinion (stock gearing) and not the 25t pinion (optional included)
so doesn't that contradict what you are saying?
By your logic he should have gone down to a 12/13 perhaps, by theirs, the smaller pinion is what fried the esc
Say Less, Do More.
skellyo
skellyo's Avatar
02.25.2009, 08:40 PM
The Flux already does 41mph on 4S with a 20T pinion and a little tire ballooning. Going to 5S, you'll want to drop 2T-3T from the 20T to get back down in the mid 40mph range if you account for ballooning.
fastbaja5b
fastbaja5b's Avatar
02.25.2009, 09:06 PM
even the flux manual says on 6s use a higher pinion than on 4s
WTF?
Say Less, Do More.
02.25.2009, 09:31 PM
If the smaller pinion caused themotor to be undergeared it would heat up. Not sure if that would affect the esc enough to cause it to pop...
Ahh, I though the 25 was stock. Must have misread a previous post. So why do they include the 25t pinion? So you can gear up if you plan to run nimhs? Does not make much sense to me...
WTF?
Can you link me to a pdf or something like that for that portion of the manual...
Even with the 20t pinon the truck is doing 55+ mph on 6s lipo. That is plenty of load on the motor. A 25t would go past 65mph. I see no reason not to run the 20t pinion with 6s, other than 55mph is a bit much for most bashing situations, and some lipos. A 16t pinion on 6s would be much more manageable, or a 19t pinion on 5s...
fastbaja5b
fastbaja5b's Avatar
02.25.2009, 09:35 PM
Here is a link to where you can download the manual
http://www.hpiracing.com/kitinfo/100646/
Even Traxxas tell you to gear up when going from a 2s to a 3s Lipo
Doesn't this all sort of contradict our conventional logic of gearing down on more cells to pull less amps and therefore less heat?
Say Less, Do More.
skellyo
skellyo's Avatar
02.25.2009, 11:23 PM
Nope, they actually recommend you gear down for 6S. That's the opposite of the HPI manual. Here's the BL E-Revo gearing chart:
http://www.traxxas.com/PDF-Library/5...anual_addm.pdf
fastbaja5b
fastbaja5b's Avatar
02.25.2009, 11:25 PM
But take a look at the manuals for the Stampede, Rustler and Bandit VXL's!
And that chart tells you to gear down from stock for a 4s, but I don't see any mention of 6s on there
Say Less, Do More.
pasan
I <3 RC
pasan's Avatar
02.26.2009, 01:34 AM
Ok, what about the balancer tolerance? Does it balance the cell you measured as 0.01v difference? I know my blinky doesn't. The most accurate balancer I have is the LBA10 (it actually seems almost too sensitive).
For your level of "anal" (), I wonder if the FMA charger would be a better choice. Has a high power limit, balance charges, and also measures cell condition/quality. To do that last item, it must be quite accurate.
I think the Blinky somehow can't quite bring the rest of the cells down to that voltage and keep them there. I usually charge while balancing. I too think a balance charger is best but I'd like a charger which actually does something more than a balance, i.e. by pushing extra juice to a weak cell to bring it up to par rather than bringing the others to voltage of the weakest cell, which IMO is very inefficient.
E-Revo - Mega ACn 22/45/1E MMM 6S
E-Maxx - Feigao 7XL MM 4S
AX10 RTR - Stock :D
Micro-T - Losi LiPo upgrade
Mini LST2 - Discarded. Useless POS.
1/8 Scale Baja Bug - Medusa 36-50-3300 eZrun 60A 3S
02.26.2009, 02:06 AM
Only way to get what you ask is to use a seperate charger for each cell. Any charger on the market charges the entire pack of cells in series. Only way to equalize them is to put a load on the higher cells and bleed off some juice. If you had a seperate charge curcuit for each cell the balancer would not be needed, as each cell would go thru the cc/cv cycle on its own terms, so to speak.
A vxl esc cannot do 4s, IIRC... 3s max.
pasan
I <3 RC
pasan's Avatar
02.26.2009, 02:33 AM
Some people have reported running a VXL on 4S and 12 cells with the BEC disabled and cooling fan. But of course that would be voiding Traxxas warranty.
AX10 RTR - Stock :D
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
02.26.2009, 03:27 AM
I wonder if the problem is the tires?
maybe they expect you to use phaltline tires with the 25t and the MT size ones with the 20t?
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
