DARKWAV
03.09.2009, 04:00 PM
Originally Posted by badbird View Post
ok I just bought a used E-Savage and need some help
2. the steering is very sloppy and tires move all over
Thanks Ron
BitHed on this forum can sell you a kit called PanicToys SuperGlide...and it is open source (instructions and parts lists on the e-sav forum mentioned above) so if you want to peice the kit together for yourself you can do so. This kity really makes the steering smooth and precise. Pretty much everyone that has tried it is amazed.
Probably also want to convert to 17mm hex wheels (E-Sav 17mm adapters available from HPI), that helps some with the wobbly wheels.
Good luck with your project...see you on the other side.
