04.10.2009, 04:43 PM
You need to swap the servo resverse on your radio for the throttle channel, recalibrate the radio, and most likely swap 2 of the motor to esc wires. Take the pinion off and see if the red or green light on the esc comes on when you throttle forward. If the red comes on you need to swap the servo reversing switch and recalibrate so that the green light comes on when you throttle forwards. Then put the pinion back on and see which way the truck goes, if it goes backwards when you throttle forwards you need to swap 2 of the motor wires.
