04.19.2009, 09:14 PM
Originally Posted by scarletboa View Post
wouldn't tightening the set screw all the way be sufficient for locking it in first?
You are not eliminating the function of the one way bearing that 1st gear rides on. Adjusting the set screw adjustment for second gear will only prevent it from shifting into 2nd gear. You need to have the 1st gear spur physically attached to the center shaft to lock the tranny. This will allow motor brakes and reverse.
To physically see this at work hold the spur gear with you had and try to roll the truck forwards, it should not move. Now try to roll it backwards, the one way bearing will allow it to roll backwards by releasing the 1st gear spur from the center shaft.
hpi p/n 100905 is the best and cheapest way to lock a savage into 1st. You will have to fool with the 2nd gear spur if you want it locked into 2nd though, no drop in parts for that yet... I bet that we could nig something up though...
