Delta Maxx
04.28.2009, 10:49 AM
yes, but the flm 3905 chassis design is with a plate on top of the brace or not?
my chassis design is with a plate under the brace and it handle the 3906, 3905 transmission and a centerdiff with a lower CG
i think it's time to redesign it again, in a length to use a aftermarket centerdriveline and to go with alternative body's
the mammuth body i use is to short and i can't find other's with a 425mm wheelbase
my thought's go with 395-400mm in length would be fine
for what?
a 3905 transmission or the centerdiff?
or both options?
the 3906 transmission is ok if you have it already(steel idler, slipper.....)
if you start with a new car and want to go for a transmission it's easier with a 3905, in my opinion
i would go with a lipoplate not cellplate (under the brace) and a brace design only for a centerdiff for me
