TexasSP
Something, anything, nothing
TexasSP's Avatar
06.20.2009, 02:02 PM
CCneu especially since you are going off road. The motor is designed for this while the medusa's are designed for airplane use. I have run the medusa's and they offer a lot of torque but again they are more designed for high air flow rate over the motor to aid in cooling. I think dagger's post above sums this up very well as others have said too.
Seeing as I don't see what vehicle you are going to run it in I can't gauge you on the gearging. However I will tell you that nothing out there will be able to run off road set up for high speed street runs without high temps.
I can run my LST2 with the CCneu geared for low 60's on the street and the temps stay in check, but if I try this gearing off road things heat up real quick. I have it now geared for low 50's which gives it good road speed and good off road power. I also have the throttle curve set so that from 0 to 3/4 throttle you only see about half power and get from half to full power in the last 1/4 of the throttle range.
www.cubicle101.com
