Its beautiful...
brushlessboy16
brushlessboy16's Avatar
Its beautiful... - 07.18.2009, 12:08 PM
Got my wheels and tires in, they are great- it was almost like they were pre-balanced!.
Also got my losi wing installed- bask in the shiny-ness because after sunday it will never be the same
07.18.2009, 07:07 PM
Looks like a sprite can. All jokes aside, it looks great Ben. Nice work.
brushlessboy16
07.18.2009, 07:27 PM
I was going for mountain dew but sprite works..
thanks ian. takin her to the track tommorow :)
Mini-update. had a problem since i had the truck. off Every jump the truck would nose dive horribly, i went with heavier springs to compensate for the weight of the truck.. ajd now have 70w oil in the shocks with #3 variable dampening pistons.. now the truck is more stable on flat ground.... I was about to jump it when my battery packs hit cuttoff.. Was this a move in the right direction?
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.18.2009, 07:45 PM
Make SURE your battery is very securely strapped down! Before I went to the races a few weeks ago, I reinforced my battery mounting plate with a bar underneath to brace it when you land off jumps, because it just bends otherwise, badly. Also I put velcro tape (sticky on one side) on both the batteries and the plate, with a single velcro buckle strap to hold in on. The combination of the two makes for a very secure hold.
