Controller Mount Idea
bigabike
Controller Mount Idea - 01.13.2006, 04:13 AM
Is this a bad idea? It is just a prototype, but I think it would work. I was thinking of modding a cpu heatsink and mounting it a little lower.
What do you guys think?
Thanks,
Rusty
stampy
stampy's Avatar
01.13.2006, 04:41 AM
If its mounted like i think it is (screwed to the mounting holes of second motor mount) then its a perfectly fine idea many people mount there controllers that way
bigabike
01.13.2006, 04:48 AM
Yep, that is what it is. Being new to RC, I haven't seen it done.
Thanks for the reply.
Nick
COOKIES!
Nick's Avatar
01.13.2006, 09:09 AM
I've done that, used a metal plate then just zipped tied it on. Where 2nd motor would go.
Sits too high though.
~ Nick.
Sneeck
RC-Monster Custom
Sneeck's Avatar
01.13.2006, 01:32 PM
Yeah, i'd make it so it still mount's there, but let's the esc sit lower. Also be sure to have enough padding on the back of the esc.
  Send a message via MSN to Sneeck
squeeforever
squeeforever's Avatar
01.13.2006, 11:16 PM
be careful with those rpm arms and the cvds. i have heard of people getting in a bad crash and the arms bending like there supposed to but when they bent the cvd came out and did some damage.
bigabike
01.14.2006, 12:32 AM
I might mount it on the lower/bottom side. RC Solutions make a metal tray I may end up with.
Thanks for the reply!
bigabike
01.14.2006, 12:33 AM
What do you use for padding?
Thanks.
bigabike
01.14.2006, 12:35 AM
Thanks for the tip. I will try to remember that when I get things runnin again.
Rusty
Sneeck
RC-Monster Custom
Sneeck's Avatar
01.14.2006, 04:36 AM
Squee,
i've bend 2 ue cvd's by running rpm arm's. They bend due to tight cornering at full speed(permax 600's motor's) no crash or jumping involded. pb depth was normal.
Rusty,
Normal foam will do. Stick enough under it.
Serum
Serum's Avatar
01.14.2006, 04:57 AM
Yeah, you really need some foam, otherwise some of the small SMD parts will fall off/get loose some day.
bigabike
01.16.2006, 03:39 AM
Thanks guys!
Working on it now.
Nick
COOKIES!
Nick's Avatar
01.16.2006, 04:35 AM
You can buy small rolls of foam celetape type stuff, thats what I use. Just stick it on your mount and ESC.
~ Nick.
CrazyPhantom
01.17.2006, 02:09 AM
what chassis is that?
bigabike
01.17.2006, 03:37 AM
FLM
