Go Back   RC-Monster Forums > Support Forums > Novak
racing with hv 6.5pro??
cornolio
cornolio's Avatar
racing with hv 6.5pro?? - 09.04.2009, 01:42 AM
anybody here racing 1/8 buggy with the hvmaxx 6.5?im planning to get a buggy and use my extra 6.5 pro system with ubec on 4s
xray xt8 MMM neu1515 1y
hotbodies ve8 novak HV 6.5
hotbodies cyclone tc
mugen mtx4(nitro)
lst2(conversion ongoing)
  Send a message via Yahoo to cornolio
cornolio
cornolio's Avatar
09.04.2009, 02:41 PM
nobody?
mugen mtx4(nitro)
cornolio
cornolio's Avatar
09.05.2009, 02:53 AM
Anyone?............
mugen mtx4(nitro)
ta_man
09.06.2009, 12:31 AM
Yes, somebody is. Ask Alvin Cheung about his experience. His screen name is "spikeitaudi" on HobbyTalk (www.hobbytalk.com). I race with him, and his Novak powered car is about the same speed as my Neu and Tekin powered cars. If you get the 14MM HV Tuning rotor your HV6.5 will run cooler.
cornolio
cornolio's Avatar
09.06.2009, 10:52 PM
thanks for the help.ill look for it there
mugen mtx4(nitro)
starscream
RC-Monster TQ
starscream's Avatar
09.06.2009, 11:02 PM
I used to race the 7.5 HVPro system as well as some others at the track.
Unfortunately, if the fan on your HV ESC fails, your ESC will let the smoke out shortly after.
I like the HV motors for small tracks and will try my 7.5 with the Mamba Pro when it's available.
Ha Ha
cmcclive
09.09.2009, 10:30 AM
I tried to race with a hv 4.5 last year. That was definately not a good idea.
This season I have been running the HV Pro 6.5 with no ill effects. The track is big but technical, there is only 1 long straight everything else is not very high speed.
The buggy can definately keep up with with the nitros, just make sure you are following novak's gearing suggestions.
I just picked up a CC BEC to try to eliminate the issue of one of my dual packs ends the run w/ 0.1V lower Voltage (onboard BEC only draws from the "batt 2" plug, but can only handle 2s lipo).
I haven't had any problems with the Novak onboard BEC, but I am hoping running an external BEC with extend the ESC and battery life (ESC=lower temp, batteries- more balanced).
For a buggy I think the Novak system is a good choice. It doesn't give you so much power that you can't handle the car. If you are a pro on the track you could probaby handle a MMM or Tekin, but it would be overpowered and hard to handle for a beginner.
tedo
Vermont, USA
tedo's Avatar
09.09.2009, 11:03 AM
I raced one in my erevo (6.5 HV) all last year. It was fine. Geared for 35-37, I never had a problem with heat. Lots of people talk smack about these systems, but I was always competitive. Most tracks you can't get past 40 mph anyway. And sensored.... oh la la.
In a buggy, you should be fine. However I do recommend a slipperential.
MBX6T: RX8 2000—sick!!!!
Campbell Buggy Rock Racer on 3S
4x4 Pede
1987 (Gen 1) Lunchbox
cornolio
cornolio's Avatar
09.11.2009, 01:37 AM
Thanks for the help guys. Anyone of you have a link to a build thread or some informative threads?
mugen mtx4(nitro)
