RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
10.04.2009, 11:05 AM
Originally Posted by J57ltr View Post
I don't know how my description is wrong other than not specifing any gear other than 1st.
Well going from say a 14:1 to a 1:14,is a big difference, because you are spinning the motor with the wheels instead of spinning the wheels with the motor, so the motor spins faster with a smaller pinion with all other things being equal. This produces higher voltages that could possibly damage the ESC. The motor is acting as a generator at this time, and it's voltage is proprotional to it's RPM.
The question was:Higher pinions = safer MMM's? Or no? Someone's lying....
Jeff
OK. Lets try this again. In your push start analogy, your scenario proves my point rather than yours. The gear ratio doesn't work in reverse as you are trying to illustrate. In your example, the engine compression represents a constant braking force if you will(force used to slow the vehicle). This braking force is STRONGER in 1st gear due to the mechanical advantage. At the SAME BRAKING FORCE represented by the engine compression, the lower gear(more reduction or smaller pinion if you will) more easily slows the vehicle - this is why you select a higher gear to start the car(higher pinion if you will). The car engine represents the motor in this case - not you trying to push the vehicle(this represents the inertia we are trying to slow). The engine (which is simulating the motor)has the mechanical advantage.
Now, I think I see what you are trying to say - higher motor rpms will deliver higher voltage . You could take the stance that a higher voltage can damage a component, which is later destroyed by current, which has been mentioned in this thread. While this statement is true, it simply is not applicable in this scenario. The motor rpm doesn't change simply by installing a different pinion.
Your very theory is an impossibility in actual practical use. If using a 2200Kv motor on 6s, the motor rpms will be the same when driven by the end user regardless of the pinion selected. Therefore, the motor speed when brakes are applied will also be the same. Yes, the truck speed will be different, but that isn't the point. The motor Kv is a constant. 2200Kv at 22 volts yields 48400 motor rpms with any pinion or no pinion at all. Unless you are suggesting that it is dangerous to quickly change to a smaller pinion immediately before you try to slow the vehicle? Nobody would argue the dangers of this actvity, but how do you do this?!
The motor does not know what gear is installed onto it. At any given voltage, the motor rpm does not change with the pinion. For this reason, the very premise of your theory is an impossibility. With a given battery and a given motor, the gearing does not impact the motor speed(aside from loading that may lower input voltage and therefore motor rpms, but this is another discussion altogether). The 'force' required to stop the vehicle is different with different gearing(ratios, mass, etc. all come into play), but at a given voltage in practical use, the motor rpms do not change by simply installing a different pinion, which is the very premise of your thought.
I think you may be too smart for your own good.
Lets all just walk away with the knowledge that better batteries and lower gearing most often leads to successful funtime with our brushless cars and trucks. :)
