Moe
01.03.2010, 05:13 AM
thanks guys. i ended up drilling a hole through the set screw and sliding it out from the motor shaft. i did make a bigger hole on the pinion and retap the screw thread so it can fit bigger set screw.
thanks for the advise
Good to hear
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Good to hear - 01.03.2010, 08:04 AM
Good to hear that it worked out for you, and that you received some good advice from RCM.
SUPERMAXX YOUR LIFE.
