bdebde
That's All Folks!
bdebde's Avatar
03.28.2010, 03:38 PM
If the charger is working properly, mah won't matter, only the charged voltage matters. I think very few chargers use the mah setting for anything other than determining max charge (if any). Think about it... if you only use 1000 mah out of the batt and charger is set to 5000mah... does the charger still put in 5000mah....NO, it charges to max voltage for lipo regardless!
