MaxxFusion
MaxxFusion's Avatar
02.16.2006, 04:34 PM
Originally Posted by makana59
Alot of guys here get the Ofna spur from Mike here... with that you'll need the 1mod pinion gear with that also. Yah the steel idler is a definate... You might also want to upgrade to CVD's.. I dont know if you already did though. Good luck with the BL. Makana
If you go with the Ofna Gear your will need the Strobe Slipper to go with it. (Recommended)
Also you will twist those plastic sliders in no time with that brushless setup. CVDs all around.
  Send a message via MSN to MaxxFusion
