07.21.2010, 11:08 PM
Got the Re-released software and unbricked my esc :)
Thank you Castle
07.22.2010, 12:41 AM
Thank you Castle
I have two more Mamba Max with the on board USB port. Is it safe to use the new software on them through the USB port now?
Blindman Racing
Powered by Mamba 5700
E-Maxx Breaker
07.22.2010, 12:53 AM
Mines not updating through the USB port or RX wire either...
So that's what all the fuss was about...
07.22.2010, 02:16 AM
i have the mamba max and used the update and in the midle of the update it falled i tried the castle link dont work the new 3.255 dont work ether the computer can't see the esc but it dos see the link but the lenk can't see the mm tryed to call castle erlyer and the phone just rings and rings
07.22.2010, 10:10 AM
Download the new update that went live last night -- you will be able to reupdate with the new version.
Patrick del Castillo
President, Principle Engineer
07.22.2010, 03:06 PM
Patrick, Will the program card work in place of the castle link? I been thinking of getting one and if it will work, good enough reason to get one
07.22.2010, 03:08 PM
Yep -- when connected to a PC the Field Link just operates as a Castle Link. So you can program all the advanced PC settings just fine with the Field Link.
Thanx!
07.22.2010, 03:15 PM
Thanks Patrick, One more question. If i can unbrick this esc, Will it still be able to use the USB on the side? Or, Will it be limited to using the card/castle link to program? Doesn't matter either way, Just wondering
07.22.2010, 04:36 PM
With the "fixed" new release of the software I was able to update the other two Mamba Max ESC's in the house through the USB port with out issue. Both ESC's are working fine and later I was able to change the settings using the USB port so the fixed software seems to have cured the issues with the USB port on the MM.
Blindman Racing
07.22.2010, 08:03 PM
Yep -- just a silly bug in the release. Everything should work fine after update.
07.22.2010, 11:50 PM
i spoke with teck suport to day and they seid for me to send it in and they will send a new one
07.22.2010, 11:55 PM
crazyjr, PM sent.
07.22.2010, 11:59 PM
Jon,
Someone should not have told you to send it in, using the Castle Link adapter will fix the problem. You shouldn't have to send in the controller, paying for shipping and having to wait to get it back; that's not fair to you for our silly mistake. Do you remember who you spoke with? There were only 3 of us on the phones the last 2 days; myself, Bernie and Greg, if you remember, please let me know; I'm pretty sure it wasn't me. :P
Please check your PM's, we will get a free Castle link adapter sent to you. It will allow you to update the controller to the latest firmware (V1.28) and bring the controller back to life; it will also allow you to use the side USB port again if you prefer it over the Castle Link adapter. Let me know if you have any questions or concerns.
Thomas Porfert
Castle Tech Support
07.23.2010, 12:03 AM
send it agan my popup blok was on
07.23.2010, 10:16 AM
the link dosnt work it stays red they tould my that the memory is not large enuf to take the new firmwar
