barnetbasher
08.10.2010, 08:58 AM
Possible bad connection somewhere- check the battery and motor leads/ connectors for a broken joint. Could be something internal thats damaged though- does the motor chime like it used to before the issue started, or do you just get lights/ dodgey chime?
Do you have an padding under the esc/ how is it held down?
thanks for the reply...ESC is glued/cable tied to chassis.
motor does not chime at all...just the lights on the esc show...they seem to
be acting normal (they show the arming is complete and respond to Tx throttle)
...the other motor i plugged in was also silent...could it be the internal connection to the motor outputs?
