Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
brian015
brian015's Avatar
03.06.2011, 12:25 PM
Originally Posted by thzero View Post
Nice work. What ProLine part # are these as I haven't seen them before? I assume that its a standard 8mm axle, but what is the pin diameter, 3mm? Also how long is the threaded shank?
Finally I assume you used a drill press? What type of jig did you use to get alignment, etc. right?
These are the adapters:
http://cgi.ebay.com/Pro-Line-23mm-He...item230e21fdc9
Part #6034-03.
The pins are 3mm. I actually use these hinge pins and cut them to length:
http://www3.towerhobbies.com/cgi-bin...I=ASCC9620&P=K
When I do some more, I'll take pics of how I did the drilling.
