Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
thzero
03.06.2011, 05:54 PM
Can't use the 3mm pin, its too small for the Baja hexes. I had thought of doing the 4mm hole as you said 90 degrees from the origin holes, about 1 or 2mm away from the original hole. Same thing would work for the LST2 axles (or any other 8mm truggy/buggy style axle).
Issue really is I don't think I have the skill to drill a new hole in the axle dead-on. :)
Thzero, with your 24mm Baja hex idea. How about using the rc8t size pin, and drill a new hole for it 90 degrees from the original holes? Or would the hole still be too close to the edge of the adapter even with he smaller pin? Brians look pretty darn close to the edge and his have held up...
