whitrzac
Can't catch this...
whitrzac's Avatar
03.25.2011, 01:19 AM
Any ideas how to get a 2 pole magnet off the shaft? I am guessing it is glued on, try some heat? I know I do not want to get the magnet too hot, but...
I have a shop press, and not ing to loose, I guess I could press the magnet off... Might shatter though.
Also, where can I get 5mm motor shafts cheap? I know outrunners use them, try ebay?
FYI, the problem is my c50 maxx motor broke the 1/8 portion of the shaft off, and I figured I would remove the magnet and replace the shaft with a 5mm one.
If anyone has a L can feiago or hacker motor or rotor they do not want, it would save me the hassle...
if you have any success, LMK...
J57ltr
03.25.2011, 11:24 AM
The only ones I have delt with are ones that the shaft has come loose and had to put them back on, but I think you could probably get the shaft hot and see if you can press it off. If it were me I would use a torch on the end of the shaft. I am sure you would have to be careful not to get it so hot that the rotor expands and shatters the magnet.
03.25.2011, 11:40 AM
My issue with heating the shaft is that it will expand, and I really want to shrink the shaft, or exand the magnet. Pretty sure you are not supposed to get the magnets over 200f, so I will try to get it up to 180 or so, while it is setup in the press. If I destroy it I do not care, it is useless as is.
J57ltr
03.25.2011, 11:48 AM
I meant shaft. You could try cooling it in the freezer, or some of that cooling spray. I am not sure if that will work, but I am not sure how else to get it loose. Most of the bonding adhesives have a temp well over 200F.
Jeff
