Go Back   RC-Monster Forums > Support Forums > CORR Trucks - Slash, SCRT10, etc.
JoFreak
JoFreak's Avatar
05.27.2011, 06:36 PM
Well, with all the nice new 4x4 SCs coming out, I finally managed to get my SCRT10 finished. Almost
Still need to get the body done and decide if I use the 6 or 7 turn Tenshock 2220 motor.
But that's how it looks for now:
Put some screws into the chassis, after I saw the chewing marks from the droop limiter screws on the chassis. They were allready there after only setting droop and ride height.
So I marked the positions of the chewing marks, put 2,5mm holes through there, tapped M3 treads, sunk them and shortened a few M3 counter sunk screws.
This is the result, front...
...and rear:
Hope this keeps wear from the relatively soft aluminum chassis and puts it onto the hardened steel screw heads, which also have the advantage that they can be replaced.
So, hope you like it so far, I know I do.
I hope to get the shell finished this weekend.
After that it's waiting for better weather so I can actually run it on the track.
