E-Maxx power problem....
studysession
E-Maxx power problem.... - 04.04.2006, 04:06 PM
I had the telescoping shafts and swapped the rears for MIP CVD's and the centers for UE dog bones.
Now it seems like I am running on half the power. Very little to no torque like it used and not sure why. I am running stock motors and feels like maybe they are bad or something. I will be switching to brushless soon - but still want to figure out what is wrong.
BTW - I am using the Intellect 3800's for my batteries. I am running 12 cells.
Thanks.....
http://studysession.com
Sponsored by:
http://www.mtroniks.net
http://www.brushless-motor.com
http://www.modelelectronicscorp.com
maxxdude1234
maxxdude1234's Avatar
04.04.2006, 04:10 PM
May sound silly, but have you checked for any binding after installing the new cvd's?
Serum
Serum's Avatar
04.04.2006, 04:11 PM
Check for binding...
HotnCold
HotnCold's Avatar
04.04.2006, 04:17 PM
correct model on the transmitter? throttle endpoints? ( and i had to say it also ) Binding?
Hows that "Hope and Change" working out for Ya???
studysession
04.04.2006, 04:21 PM
I am using stock radio gear for now..... What is there to change? I can turn the wheels freely - not saying no, but definately doesn't seem to be binding that I can see anywhere...
Sponsored by:
HotnCold
HotnCold's Avatar
04.04.2006, 04:48 PM
If i remember correctly there is a dial for the amount of steering and throttle. Its been a while since i saw the stock radio gear. And when its on the ground - does it roll freely?
studysession
04.04.2006, 06:08 PM
Yes - it does roll freely in air and on ground. Thanks
Sponsored by:
coolhandcountry
coolhandcountry's Avatar
04.04.2006, 07:58 PM
You didn't knock a motor wire loose while working on it? Did you try to reprogram the esc?
studysession
04.07.2006, 04:37 PM
Definately not my drive train. The new motor and ESC works fine. The stock motors lost their punch even though they were only ran a dozen or so times.
Sponsored by:
Sneeck
RC-Monster Custom
Sneeck's Avatar
04.08.2006, 12:16 AM
Make sure all the drive cup's are tight and not spinning on their shaft's.
Also check if you didn't loose one of those wheel pin's for the wheel hex.
  Send a message via MSN to Sneeck
studysession
04.08.2006, 05:51 AM
THanks - but I posted yesterday saying it ended being the stock motors. I replaced motors and ESC and all was fine.
Sponsored by:
