Dragonfueled
Nore more bump boxes and after run oil
04.30.2013, 07:17 PM
Did some more testing. When I punch the throttle the green and yellow led light up till the rpms come up then the yellow goes out and I get full power. If I maintain some rpm and punch it I no longer get the yellow light and I get full power rite away, let the rpms drop to much and when you nail it the yellow light comes on with the green one again till the rpms come up again. Any ideas?
Brushless ..... I put that s... In everything.
05.01.2013, 10:27 AM
Bad controller, send it in
Dragonfueled
05.01.2013, 06:47 PM
It's firmware related. If I update to 1.39 firmware on my old monsters it does the exact same thing. Once I go back to 1.32 it's fixed. You guys don't have this problem with 1.39 firmware in your monsters? If you give it throttle and the yellow light stays lit with the green one for two seconds you have the same issue.
Overdriven
Destroyer of Tires
Overdriven's Avatar
05.03.2013, 08:23 AM
That sounds like its staying in its "startup" algorithm too long. Firmware might be to blame, maybe try reinstalling the firmware if you can. The other possibility is the firmware is fine and the esc is staying in "startup" algorithm too long because it doesn't detect the emf feedback from the motor the way it should. If that's the case it's hardware related and needs to go back to Castle.
Dragonfueled
05.03.2013, 08:58 AM
I sent castle a vid and they said the are aware of a few people with this problem but don't currently know the cause of it. It's in the firmware but I can't revert to older firmware cause the monster2 only has 1.39. I went back to 1.32 on my old ones and they are perfect. Oh well waiting on new firmware :)
outlaw
Castle addicted
outlaw's Avatar
05.04.2013, 04:50 PM
On the Monster 1 anything newer than Firmware 1.24 does not have really nice startup parameters
goes from "odd" to "total fail"
I guess, the "good old" Version 1.24 for the Monster 1 does not work on the Monster 2
On the Monster 2 the 1.32 is currently the best choice, but not as nice as the 1.24 on the Monster 1
Same does apply to the Mamba Max Pro
Best Firmware here is 1.26
I had a talk with Richard this year on the Toy Fair in Nuernberg
regarding this issue and some other minor things on the latest firmware versions.
I offered some intensive firmware testing for Castle, but no reply yet....
kind regards
Mirko
Brushless motors have to be green ....
Dragonfueled
05.04.2013, 08:13 PM
I wish I could force some older firmware onto my monster 2 lol. Yeah 1.24 is nice . My monster2 only had 1.39 on it so I can't go back.
