RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
04.07.2005, 06:07 PM
The UE shocktowers will work fine. The turnbuckles actually run from the motor mount to the shock tower. You screw the extra rod ends through the motor mount plate and shock tower into the extra rod ends (rod ends should face each other between the rear shock tower and motor mount). Then, you put a screw through the mounted rod ends and the turnbuckle rod ends with a nut on the other side. Sorry, I don't have a picture, but hopefully the explanation was helpful.
