Badawan
09.20.2006, 05:34 AM
Originally Posted by Nick
I plugged it in and I set it up fine with my transmitter but when I accelerate/brake the motor doesn't move. The lights come on correctly though, forward = green, yellow = neutral, red = brake.
When I set it up and turned it on, it "beeped" the motor, which shows it can control it.
Any ideas?
Check you have set the LVC to right voltage? I once carelessly set LVC to 14,8 V and I had 11,1 V Li-Po, it just flashed the ligts.. If you have too small start power, it would beep?
