Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
??9920 and plastic center gear??
Big Daddy
??9920 and plastic center gear?? - 10.17.2006, 10:51 AM
I was curious about when the BK warrior 9920 controllers would be back in stock cause I know they have been on backorder for quite awhile. Unless I just miss it when they are in.
And I also am looking for a plastic spur gear for my hellfire, it uses a center diff and I am having a hard time finding a gear that I can use with it and my brushless motor.
THanks guys,
BIG D
Serum
Serum's Avatar
10.17.2006, 12:59 PM
I think you can use a kyosho spur on that. I thought it uses the same cups as the savage.
meatzardd
#4
10.17.2006, 09:04 PM
you could use the hardened steel mod 1 piions mike has against the steel spur on the hellfire. http://www.rc-monster.com/proddetail...ED_PINION_MOD1
squeeforever
squeeforever's Avatar
10.17.2006, 09:46 PM
Thats not wise....They still don't last for some reason...MacII went through several...The plastic spur Rene mentioned is what you need. It should bolt right up..
10.17.2006, 10:05 PM
Why is that I wonder? After all, the stock Nitro engine uses a hardened steel clutchbell. :032:
squeeforever
10.17.2006, 10:43 PM
I dunno either...
jhautz
jhautz's Avatar
10.18.2006, 01:17 AM
Doesn't mater anyway. They are out of stock too. Have been for a while. :010:
to make it...
or break it...
Silent...But Deadly
Big Daddy
10.18.2006, 10:47 AM
any where else I can get one?
Serum
Serum's Avatar
10.18.2006, 10:52 AM
the kyosho's are available thru Mike.
jhautz
jhautz's Avatar
10.18.2006, 11:00 AM
I meant the hardened mod1 pinions are out of stock.
to make it...
or break it...
Silent...But Deadly
Serum
Serum's Avatar
10.18.2006, 11:05 AM
Towers has got some hardened pinions. but they appear to be not so hard...
Big Daddy
10.19.2006, 12:29 PM
alright thanks guys, I will have to order me one. (well probably two in case I tear it up)
VintageMA
VintageMA's Avatar
10.19.2006, 01:18 PM
If you are referring to the Century motor gears from Tower, I would recommend against them. They are not that 'hardened' - I have gone through a 14T gear in about 45 minutes of driving.
I hate to mention the name here, but CF of FD uses a true hardened Mod1 clutchbell with a 5mm mount epoxied in place that may add just a little weight at the motor, but I have been running one in a Kyosho MP7.5 conversion with a metal spur with no problems.
“Everyone has a right to be stupid; some people just abuse the privilege.”
Big Daddy
10.20.2006, 04:21 PM
you got any pics of that conversion? That is my next project
VintageMA
VintageMA's Avatar
10.20.2006, 05:10 PM
http://www.rc-monster.com/forum/showthread.php?t=4119
