the pro would normally have to spider diffs( or so it does in belgium)
those diffs use 6 bolts instead of 4.
if you get the pro you'd have to swap the diff for a normal one.
if however you get the rtr or a version without the spider diffs, you can just use the kyosho spur.:027:
