03.21.2007, 06:11 PM
Serum,
Aren't the maxamps lipo's good cells ? I also use the 6000mAh maxamp's and the Orion platinum lipo's.
The cogging only occurs when driving on high bite carpet. When driving on asphalt with rather sweeping turns I don't have that problem. It seems like it only coggs after slamming on the brakes. I feel like the MM ESC needs a little time to shift from brake to trottle. When punching the gas just after braking it coggs a little but too much so it creates a sweep-out. The front wheels just lock for 1/10th of a second and the rear end comes around because I'm in the middle of a corner. Very frustrating.
I'm not even sure it really is cogging. I don't thinck it's because of bad batteries. I'm using maxamps for almost 2 years now in different applications and the problem only occurs with the Mamba Max motor and ESC on carpet. I also have the novak 3.5 in a TC and it's great and smooth like butter.
I'm thincking sensorless ---- sensored, maybe sensored isn't that bad at all for some applications like carpet.
Do you thinck the Lehner XL5000 will have better acceleration compared to the novak 4.5 or 3.5 ? And what about the speed ? I don't thinck the lehner will be faster since it's only 5000Kv.
To be honest , my novak GTB and 4.5 system is faster than my MM7700 in the same car and using the same juice. I still like the Novak's allot.
