04.14.2007, 05:10 PM
Crikey, that motor looks big on there! I would say no more than an S size, or maybe an L motor!
pb4ugo
04.14.2007, 11:41 PM
Given the light weight, I would really recommend a short can motor on 6 to 9 cells. As far as the battery mounting. some good old Associated battery cups would be perfect.
sven
sven's Avatar
04.15.2007, 12:18 AM
Thank you all for the suggestions.
I have an original Novak SS system around here somewhere. Maybe that would work better? Only 7 cells max though.
I guess I need to work on the buggy so I can find this 9xl a home.
AAngel: Yes that is a type of plastic, known as Delrin. It is very stiff and machines nicely (doesn't gum up the cutting bit). I just did some rough cuts with a bandsaw and will clean it up on a mill when I get a chance.
BrianG: Is an 'S' a 280 size motor?
pb4ugo: I tried some of the Associated cups, but they didn't quite fit due to the raised sides of the chassis. I will probably end up milling out my own trays.
