Originally Posted by Shonen
I'm not sure, I haven't tried but I believe Castle had a feature on 1.29b that flashes an LED if you overvolt a Mamba ESC. I'm not sure if this disables it from driving, but Mamba XL firmware was added in 1.27b so if it becomes a problem there is a workaround.
I don't want to overvolt per se; but the MM (for example) was a 3s ESC, but would work on 4s or even some on 5s. Then, the CCBEC Pro is rated differently depending on if motor braking is used or not. I was just hoping CC was doing something similar with the MMXL and could go higher if motor braking was turned off.
