Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
brian015
brian015's Avatar
04.18.2011, 06:12 PM
Cheers Brian!! ill let you know.
Are any of your problems ESC/Motor related or weight issues? i wouldnt mind knowing as i could learn from what you have experienced and hopefully avoid such problems?
Thanks for the help!!!
I finally had one of these diffs fail - the rear. It was one of the internal spider gears that went bad. I then had an accident with it today after driving it for about a minute and broke the output cup on the same diff I just rebuilt.
I also replaced the center diff cup because I thought that was the problem initially - it got pretty hot a few times and the plastic hd case seemed to be deforming slightly - but I don't think it was really a problem, because the internal gears were OK.
I also had drive shaft screws come loose from the front and rear diff pinions on separate occasions - meaning I had to stop driving and come home to fix them - now they're loctited - so hopefully it won't happen again.
Anyways, I've been working on this much more than driving it recently - keeping me from my other build.
